Re: H Carb. Factory Settings
Posted by CNKS on July 29, 2006 at 18:00:32 from (204.249.178.138):
In Reply to: Re: H Carb. Factory Settings posted by CNKS on July 29, 2006 at 17:53:02:
Or if by "factory settings" you mean while running: With engine warm at wide open throttle turn main adj in until engine stumbles, out until smooth plus maybe a quarter turn. Idle rpm is set so that it runs smoothly. Idle mixture is set by turning screw either way until it runs smooth. It should not stumble when the throttle is rapidly opened. You may need to do both more than once.
