Height of 3 pt lower arm on a Farmall 504???
Posted by jessboyd1 on July 29, 2006 at 20:32:18 from (24.119.127.117):
I have a Farmall 504 and just bought a 3 point post hole digger for it. The 504's 3 pt lower arms won't raise high enough for the auger blade to come to the vertical. The center of the holes on the lower lifting arms, the ones the yoke's pins go through, measure 27 inches from the ground maximum. The sway chains don't quite become taut so that is not the reason the lower arms don't go higher. Could someone with a 504 measure the distance from the ground to the center of the holes in the lower lifting arms on their 3 pt hitch. Thanks in advance
