Re: Best way to clean SW6 gas tank
Posted by sgtbull on July 30, 2006 at 06:51:44 from (65.73.245.242):
In Reply to: Best way to clean SW6 gas tank posted by JaredM on July 30, 2006 at 06:39:06:
Next time you're doing some fieldwork, SECURELY strap the tank inside your rear tractor wheel after adding about a pint of nuts. (Don't use rocks, they just end up adding a lot of dust that can be hard to rinse out.) Every once in a while, reposition the tank to get the nuts to contact other areas. It'll do a surprisingly good job.
