Re: coil w/ internal resistor PLUS external resist
Posted by Janicholson on July 30, 2006 at 10:00:45 from (66.173.50.10):
In Reply to: Re: coil w/ internal resistor PLUS external resist posted by e-manhunt on July 30, 2006 at 07:13:54:
The ignition provides only the initiation of the combustion process. If it works it works. It will have no affect on the loud or hot. Timing however will. Adjusting the points to .020" (correct) might change the timing enough to warrant a check. Look in the archives, there must be fifty entries on timing an M. JimN
