Farmall Tractors Discussion Board
Super A misses
Posted by Daniel on January 22, 2000 at 11:32:01 from (152.163.201.77):
My recently restored Super A has begun to miss. It sort of pops like a John Deere! I've got the miss at low, mid, and high idle. It had been running good, but I've had it split to replace a leaking freeze plug and when we started it up today it the problem started. We also replaced the springs in the govenor, and the high RPM is now right, but if you idle it down below 600 or so it dies. I let it idle long enough to get hot. The plugs are Champion D18's and upon inspection are black and sooty. The wire are belden soild and are about 2 years old, plugs were new in July and I haven't run it much. I also replaced the rotor and Dist. cap in July as well.
Any ideas? Thanks, Daniel
Post A Followup
: Re: Super A misses
