Re: cub running hot
Posted by Janicholson on July 31, 2006 at 12:08:19 from (199.17.6.122):
In Reply to: cub running hot posted by averille on July 30, 2006 at 07:22:16:
If the water level is above the location of the inlet from the engine, and it still gets hot enough to boil water, two things might be looked at.
Looking down into the radiator with a good small light, do the tubes look corroded and plugged up? if they do that is a good reason to have it "rodded out" at a radiator shop.
The block tends to get scale and rust chunks mixed with a mud like gunk in the bottom of the cylinders. A quality reverse flush of the system, using a good radiator flushing agent might help. JimN
