Re: ethanol
Posted by JT on August 01, 2006 at 06:13:35 from (70.226.226.99):
In Reply to: ethanol posted by dig on July 31, 2006 at 17:17:24:
One of the biggest things with E85, you need to get rid of all rubber parts, this stuff will soften any rubber parts and make them like bubble gum. We have a bad time with gasahol and fuel lines, so E85 will be worse. and make sure your fuel tank has been cleaned, spotless, the E85 will clean every bit of rust, dirt, etc out of every part of your fuel system.
