Re: Hey Tractor Vet -1066 clutch
Posted by the tractor vet on August 01, 2006 at 10:56:41 from (75.24.41.29):
In Reply to: Hey Tractor Vet -1066 clutch posted by Michael Sheik on August 01, 2006 at 10:50:57:
It would be a wise thing to do as the clutch adjusments should be done every soften . Now when doing the rebuild on the clutch assit cyliner myself i like to run a brake hone thru the cylinder to give it a new surface but use fine grit stones . Now when adjuting a hyd. clutch the adjustments are just a bit differant on the free travel set up but the rest if done the way i do them it is the same .
