Re: 1954 Farmall C
Posted by El Toro on August 01, 2006 at 15:41:34 from (64.12.116.65):
In Reply to: 1954 Farmall C posted by Stuart Hooser on August 01, 2006 at 09:06:23:
Make sure you have battery voltage at the points.
Check the new points for any grounding against the distr. body. Some new condensers are defective. Hal
