Re: Another 6v-12v question...
Posted by CNKS on August 01, 2006 at 17:06:45 from (204.249.178.138):
In Reply to: Another 6v-12v question... posted by JohnG(TX) on August 01, 2006 at 15:42:51:
I assume it has a magneto. If you are not using the charging system or lights, you probably have the belt off the generator. A good 12 volt is good for many starts before recharging. I wouldn't use a 6 volt unless you fix up the charging system -- no advantage at all. I agree with Cowman that 6 volt is marginal for an M. Everything has to be kept perfect for reliability.
