Re: TA Replacement on Farmall 560?
Posted by Gary in Mozarks on August 02, 2006 at 03:26:20 from (64.240.21.171):
In Reply to: TA Replacement on Farmall 560? posted by linesplice on August 01, 2006 at 09:59:41:
I pulled a stupid move and threw the TA on going down a hill in roadgear on my 460D (same same) I didn't know that mechanical TA's were different that hydralic TA's! Anyway I ended up putting a new TA Clutch, Flywheel and Pressure plate. Having never done it before I thought it was a big deal. I had use the gantry chainfall to hold up the back end of the engine then build a frame out of angle iron to support the Tranny with a floor jack and then split them. The hard part was putting it back together correctly. I listened to the wrong "mechanic" and ruined my main clutch plate. The correct way is take the PP and clutch off the flywheel and put the PP on the outer splines of the tranny, the clutch on the inner splines of the tranny and then put the unit together. Once you have them together, rotate the flywheel till the PP holes line up with the flywheel and gradually draw down the PP bolts. G
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
