Re: M with Super M sleeves question
Posted by Janicholson on August 02, 2006 at 10:46:46 from (66.173.50.25):
In Reply to: Re: M with Super M sleeves question posted by greasemonkey on August 02, 2006 at 09:18:53:
If you can get at the crack to work on it, I would pin the crack (see archives on process) be sure to drill the ends of the crack prior to all other avtion. Magnafluxing is wise to be sure where the crack is located. If it goes much into the block past the waterjacket, I think it is toast. good luck, JimN
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
