Farmall Tractors Discussion Board
Re: Re: Re: power steering 300 Utility
Posted by MrG:Not a Problem... on January 22, 2000 at 16:00:13 from (205.240.115.25):
In Reply to: Re: Re: power steering 300 Utility posted by JLE on January 22, 2000 at 14:24:42:
The "T" bracket on the bell housing of my 350 w/std steering is identical to the "T" bracket that my supplier thoughtfully included on the PS unit he shipped me. 6 bolts on the clutch/transmission casting, plus one into the mounting hole on the "T" bracket and she's in.
Had to do some custom (manual) rebending of the steel return line, but that's in, too. Now all I need is that pressure line and the flow control valve and I'm back in business.
Problem: Case-IH does NOT have the grease seal boots that connect the drag link tie rod ends to the rocker arms on the ne PS unit (we destroyed the old ones with the pickle fork. And there are TWO differnt part #'s! Depending on which drag link the tractor has! Evidently they sourced out to two different companies for the links. (How can I tell exactly WHICH one I have?)
These seals (grease boots as I call them) ARE available on a complete new tie rod end (at $70 a PIECE!). Heck with that noise! I'm gonna find new seals at NAPA or go without! Any ideas?
Post A Followup
: Re: Re: Re: Re: power steering 300 Utility
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
