Troubleshooting a 340U FastHitch
Posted by PaulW_NJ on August 02, 2006 at 21:04:33 from (70.111.112.70):
I could use some help from the hydraulics experts troubleshooting the FastHitch on my 340 Utility. It is the Tel-a-Depth type hydraulic hitch, which has the FastHitch lever beside the seat on the right side. The control valve for the hitch is up in a control valve manifold under the dash and is connected to the FastHitch lever through linkage that runs under the seat. When I move the lever up (even a little bit) and stop, the hitch continues to move all the way to the top of it’s range. When I move the lever down, the same thing happens but down to the bottom of it’s range. I can’t get the hitch to stay in one position without going all of the way up, or down.
I located a Blue Ribbon Service Manual for Hydraulics Troubleshooting (GSS-1280), but I’m stuck on the terminology. I’m not sure how to relate the troubleshooting list of problems to what I am experiencing. Could it be “Control Valve Will Not Center Itself In Neutral”? If so, it suggests a "centering spring" in the control valve might be broken.
Has anyone had this problem? Any suggestions would be welcome.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
