Re: Oil Chang for M (What oil to Use)
Posted by Janicholson on August 03, 2006 at 09:01:30 from (199.17.6.122):
In Reply to: Oil Chang for M (What oil to Use) posted by Wisconsin Cowman on August 03, 2006 at 08:43:08:
The choice of oils is controversial. I believe that an engine that is not running hot, and has no issues with coking in valve stems can be better protected with multi wt oils. 10-40 or 15-40 brand name oils. I also believe in synthetic oils (ames oil, mobile 1 etc. In an M used in a way that it was intended, I would use 10-40, or 15-40 oil. If it was loose, and had marginal oil pressure when hot, I would use a 20-50 oil, or a straight wt40 oil. In tractors that coke valves, (some IH gas 6 cylinder units, I would use straight wt 30).
By the way, and without flame in any way, the reaction to your name is in response to the high visibility and authority from respect that Nebraska Cowman has earned through his dedication to all forum participants, his knowledge, and his ethical stance. (read the article attached in the post below on Nebraska Cowmanand below), his consistant positive attitude, and the fact that we associate the Cowman name with him. If I were you, I would choose a different screen name, and let it be known in a post to that effect. The participants of this forum would be appreciative. JimN
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
