Re: coil replacement
Posted by Janicholson on August 03, 2006 at 12:50:52 from (199.17.6.122):
In Reply to: coil replacement posted by '43 h on August 03, 2006 at 12:46:36:
It will work fine. Just won't look stock. Use longer wires if the originals are short. Not an issue. Negative term to distributor. Jimn
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
