Re: Cub axle leaking terribly.
Posted by Merlin on August 03, 2006 at 13:18:05 from (209.205.161.54):
In Reply to: Cub axle leaking terribly. posted by Greyson Noles on August 03, 2006 at 08:30:09:
How full did you fill the transmission? It's not supposed to hold but about 3 pints. Look on the left side of the tractor between the fender and transmission housing down toward the bottom of the transmission and you will see a 1/4" pipe plug. Remove it and when it stops running, it will be at the proper level. If you over fill the transmission, even a new seal can (and probably will) leak.
