Re: Cub axle leaking terribly.
Posted by steveb05 on August 03, 2006 at 13:37:37 from (72.12.197.68):
In Reply to: Cub axle leaking terribly. posted by Greyson Noles on August 03, 2006 at 08:30:09:
You may want to drain the transmission it sure looks like you have some water mixed in the oil. Do not try to plug the hole it will then run out the front of the housing where the brake rod enters the housing. It Appears that you have a seal leaking between the transmission and the final drive and the transmission is over filled
