Re: 656 Farmall
Posted by Aces on August 04, 2006 at 09:13:41 from (65.54.155.44):
In Reply to: 656 Farmall posted by MIDNIGHT on August 04, 2006 at 07:41:59:
Midnight The right way is pressure test and to do that you beed special fitting to kock up gage. To adjust pressure the valve stem out the top of the PTO needs to screw up into the square nut at top of stem. Move the handle that operates the PTO so you can see what moves at left top and you will see the stem move in and out of the PTO. Screw the stem up into the nut and see if it helps if not you will need new clutch. But you realy need gage.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
