Re: Gas type?
Posted by Nebraska Cowman on August 04, 2006 at 09:42:12 from (65.169.97.206):
In Reply to: Re: Gas type? posted by TCcanoe on August 04, 2006 at 09:08:30:
You CAN use modern high detergent oil in your old tractor. Most of us do and have for years. There are many reasons modern engines last longer including tighter tolerences, better filtration and dirt exclusion, more eficient and complete combustion. etc.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
