Re: Gas type?
Posted by Wild Bill on August 04, 2006 at 10:29:55 from (65.54.155.43):
In Reply to: Re: Gas type? posted by magman on August 04, 2006 at 09:59:53:
you can use diesel oil in a gas engine, but not gas engine oil in a diesel.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
