Re: Gas type?
Posted by RustyFarmall on August 04, 2006 at 12:02:47 from (199.120.81.245):
In Reply to: Re: Gas type? posted by Mike CA on August 04, 2006 at 11:43:22:
Mike, use the high priced stuff if you want, it won't hurt anything, but ANY engine that was designed to run on low octane fuel will not benefit one little bit from use of high octane. You will just be throwing your money away. The exception would be if you made some serious compression and timing modifications to the engine, at which point that engine would no longer be what it was designed to be, and then the high octane fuel definately would be beneficial.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
