Re: Gas type?
Posted by F-Dean on August 04, 2006 at 12:57:32 from (67.72.98.91):
In Reply to: Gas type? posted by Mike CA on August 04, 2006 at 08:33:06:
I use gasohol in my cars and truck but not in my tractors. I use gas without alcohol in my tractors because the alcohol can evaporate if you don't use the tractor for while like over winter and all you have left is some low octane gasoline.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
