Re: Gas type?
Posted by Steven@AZ on August 04, 2006 at 16:32:22 from (24.121.155.253):
In Reply to: Gas type? posted by Mike CA on August 04, 2006 at 08:33:06:
Lead additives are a waste.
Run regular 87 or even 85 octane fuel in your H. The compression is so low that high octane fuel will be nothing but a waste of money.
I run Mobil Delvac1 5w-40 in my H. 75 psi oil pressure all day long at anything above idle speed. Hot low idle it drops to 50 psi.
Pull the oil pan off any tractor you buy - if there is sludge, clean it out as best you can. Then run modern oil in it.
As for the oil filter doing nothing - I believe it started on the H's and M's that full pressure lubrication went mostly through the filter. I know this much for sure: if you leave the filter loose it will pump the oil out in a matter of a few seconds (don't ask).
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
