Re: Gas type?
Posted by Hugh MacKay on August 05, 2006 at 02:54:38 from (216.208.58.178):
In Reply to: Gas type? posted by Mike CA on August 04, 2006 at 08:33:06:
Mike: These old Farmalls never did need lead or high octain gas. Those features were designed for high performance, high rpm engines and your Farmall is neither.
I've been running unleaded gas in Farmalls, now close to 40 years. I've probably had rebuilds done on 10 of these engines and all of them needed piston and sleeve kit long before head and valves gave trouble. My dad bought a Farmall 300 new, I do not have it currently but do know it's on the 6th set of pistons and sleeves. It was rebuilt roughly every 4,000 to 5,000 hours. I do remember on a couple of those rebuilds the head required little or no work. I can say much the same for my Farmalls Super A and 130.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
