Re: Anther M gas tank question
Posted by huntingreen on August 05, 2006 at 22:27:18 from (68.112.68.85):
In Reply to: Anther M gas tank question posted by Paul G. in Mn on August 05, 2006 at 17:36:41:
The tanks are seam welded. It is a spot welding process where the 2 halves are placed between 2 copper wheels. These wheels act as the welder tips. Takes a lot of electricity. Probably was also a water cooled welding process.
