Re: 1020 McCormick Deering
Posted by Nebraska Cowman on August 06, 2006 at 19:29:58 from (65.169.97.206):
In Reply to: 1020 McCormick Deering posted by McCormick Deering John on August 06, 2006 at 18:35:28:
Well, let's see. Under the nut is a disk with holes in it. That slides off. Then you will see another disk with a peg sticking out. That disk is threaded on. I usualy tap on the peg with a screwdriver to get it started turning, then it should spin right off. They can be a real bear if the threads are nicked up cuz they are hard metal and a pipe wrench won't grip well.
third party image
