706 brake bolts
Posted by jim mc dade on August 07, 2006 at 05:03:29 from (216.234.99.38):
hi i removed the the cover plate to the range transmission this weekend to repair the snapped linkage shaft. it can off after much fiddling. the park brake lock assembly(spring loaded) was missing 2 of the three 1/2" bolts that holds to the underside of the plate. The shaft that the pawl pivots on had worked itself out and looked like it was going to fallout shortly. I felt around in the bottom of the housing and could not find the bolts( i could not reach in all the way to the rear) would there be a problem with leaving the bolts in there ? or should I try to get them out?
