Posted by glennster on April 10, 2009 at 17:31:21 from (24.14.63.246):
In Reply to: CRANK PULLEY REMOVAL posted by cessnapilot3@gmail.com on April 10, 2009 at 17:05:57:
soak up the pin and set screw real good with pb blaster. then you need to remove the set screw. after that is out, drove the pin out of the crankshaft with a brass drift so you dont mushroom the end. the big nut is 2 1/2 inch i think. i have a big open end wrench that i use to take em off. once off, use a 3 jaw puller to remove the crank pulley. its not a press fit. check the seal surface on the crank pulley for a wear ring area. if so, it will need at least a speedy sleeve. my machine shop guy cut the groove off my pulley on the lathe, then put a press fit sleeve on.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
