Re: 52 Cub stuck in 3rd
Posted by john *.?-!.* cub owner on August 07, 2006 at 19:17:02 from (66.112.43.44):
In Reply to: 52 Cub stuck in 3rd posted by knbshn on August 07, 2006 at 16:55:32:
try the link below, or if it doesn't work, copy and paste thsi into your browser.
http://www.cleancomputes.com/Cub/Maintenance%20Tips%20and%20Techniques/Articles%20by%20George%20Willer/Cub%20Shifter%20Repair/Cub%20Shifter%20Repair%20and%20Improvement.htm
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
