Re: real IH wide front end?
Posted by Glenn F. on August 08, 2006 at 03:15:43 from (4.254.65.31):
In Reply to: real IH wide front end? posted by Mike CA on August 08, 2006 at 00:04:20:
If I were you, I'd go ahead and get the narrow front, but keep the wide front. They're easy to switch over. The day will come when you'll wish you had the wide front back. Narrow front H's are VERY common. Factory wide front models are very rare around here.
Glenn F.
