Re: farmall a question
Posted by Mikey D on August 08, 2006 at 05:24:19 from (70.149.201.199):
In Reply to: farmall a question posted by Michael Beaudry on August 08, 2006 at 04:20:44:
If it is shooting out black smoke when it sputters, it is running rich. You'll need to check carb adjustments and/or float level. If no smoke, then it is either too lean (carb adjustment or fuel restriction) or the ignition is breaking down. If ignition, I'd start with points because they are cheap, but it really sounds like the coil may be the culprit, since the hotter it gets under load, the more likely it is to suffer from coil breakdown. You could put it under a load first thing in the morning, before the coil gets hot, and see if you have no sputter, or even a lot less sputter.... I would say also check for water in fuel, but I would expect a sputter most all the time with that - not just when under a load. mike
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
