Re: real IH wide front end?
Posted by Mike CA on August 08, 2006 at 08:07:31 from (214.1.211.251):
In Reply to: Re: real IH wide front end? posted by banjo on August 08, 2006 at 00:30:46:
Good question. It has nothing to do with the usability of a wide front end. I'm not going to use this tractor for work. It will be strictly a show tractor. And the reason I want a narrow front end is because that is what my Grandfather had. I want to rebuild "his" tractor for my own. And the wide front end just isn't the same.
