Re: real IH wide front end?
Posted by Mike CA on August 08, 2006 at 08:31:55 from (214.1.211.251):
In Reply to: Re: real IH wide front end? posted by Allan In NE on August 08, 2006 at 02:46:56:
ok, it sure does. Allan, could you send me a high resolution, close up detailed picture of your wide front end? The reason I ask is that there is a push bar on the front of mine, but it is broken and bent, and a chunk of the bar is missing. I want to know if that is supposed to be there or I should remove it. I can't really tell by looking at your picture, but it doesn't look like yours has it.
