Farmall Tractors Discussion Board
Re: IH 350 Inspection Pointers???
Posted by RickB. on January 23, 2000 at 04:47:01 from (205.231.28.122):
In Reply to: IH 350 Inspection Pointers??? posted by Bob Kirk on January 22, 2000 at 15:21:07:
You probably won't be able to tell about the hyd pump seal on a quickie inspection, especially if you have a crafty seller. There is no timing chain or overhead cam on this engine, all gears & pushrods. If it has no TA, it probably has transmission (non-independent) PTO. Manual steering as others note, make the use of a loader a poor choice. Inspect the steering box for excessive play, leaking pitman arm seals, etc. these parts are high-wear & spendy. Not to say this isa bad tractor, though, just some stuff to look at. Happy Hunting!
Post A Followup
: Re: Re: IH 350 Inspection Pointers???
