Re: Changing PTO shaft H farmall
Posted by NDS on August 09, 2006 at 10:54:03 from (205.188.116.133):
In Reply to: Changing PTO shaft H farmall posted by Greg Burns on August 09, 2006 at 10:42:16:
The early Hs have a slot or dog drive PTO while later ones (beginning in early 1941) have spline drive. To put later PTO in early tractor requires transmission countershaft to be changed to spline drive type.
