Re: 826 Brakes, Brake PIston Insulator
Posted by K.B.-826 on August 10, 2006 at 22:56:57 from (68.115.99.190):
In Reply to: 826 Brakes, Brake PIston Insulator posted by Jim Allen on August 10, 2006 at 19:17:27:
Yep Jim, epoxy them on. Did you replace the bull pinion seals? Now's a good time to do it. Also, make darn sure your bull pinion shafts don't have any play in them, or the seals will leak. They're pretty easy to reshim, although you do need a depth micrometer. The ability to reshim the pinion shafts without removing the axle housing was one of the best improvements that the late 56 series/26 series had vs. the 06/early 56 series.
