Re: Super A replacing brakes
Posted by gene bender on August 11, 2006 at 03:39:43 from (66.43.221.106):
In Reply to: Super A replacing brakes posted by B F on August 10, 2006 at 20:22:50:
The big thing is securing the tractor. I use a cherry picker to hold the final assys when they are removed from the tractor as they balance well with the wheels removed. You have to remove the drawbar first. Then you can support the tractor with the drawbar removed. I would only do one side at a time. You will probably need to replace the seals.
