Re: FARMALL 100 RADIATOR QUESTION
Posted by scotty on August 11, 2006 at 05:52:37 from (199.231.49.128):
In Reply to: FARMALL 100 RADIATOR QUESTION posted by NICK D on August 11, 2006 at 03:58:33:
Mornin Nick,
I think that will work. If you were going the other way and tryin to put a Super A grill over a 100 radiator you might have a problem because of the overflow tube wouldnt work with the Super A grill.
Maybe others will jump in and offer some insight!
scotty
