Re: H axle seal replacement
Posted by Theman on August 12, 2006 at 05:11:10 from (65.248.77.5):
In Reply to: H axle seal replacement posted by Rock2000 on August 11, 2006 at 21:29:40:
The seal has to come back out the same side that it went in. To get the seals out of the caps on my H, I set them on my vise opened wide enough the seal will clear as it comes out. You could also use a couple of pieces of wood too. Then, a punch or small chisel is used to tap them out. Patience and care will keep you from damaging the cap.
