Re: Brownie 45- voltage regulator for 6V gas gauge
Posted by Brownie 45 on August 12, 2006 at 05:14:52 from (207.177.82.189):
In Reply to: Brownie 45- voltage regulator for 6V gas gauge posted by GA Dave on August 11, 2006 at 20:18:35:
NTE is a good line of replacement semi's. Be sure to put a small amount of silicone grease or heatsink compound on the back of the regulator to provide heat transfer when mounting it. NTE & ECG replacements are a bit high, but as you said, no postage.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
