Re: Farmall Starter
Posted by Dave Grindle on August 12, 2006 at 07:29:29 from (207.190.64.200):
In Reply to: Farmall Starter posted by Crusher on August 12, 2006 at 06:38:59:
pos or neg ground makes no difference ......the only reason you'r starter does'nt work on poss ground would have to be that for some reason you'r not getting a good connection somewhere (when hooked poss ground).....HOWEVER (you may need to have your starter rebuilt & / or find a different one anyway) because a 12 volt will spin a marginal starter sufficiently while a 6 volt will not - precisely the reason why a lot get converted to 12 volt in the first place ( converting to 12 volt is an "easy" fix for a weak starter &/or poor batt cables or connections ....or for an engine that is not tuned properly ) you need HEAVY cables for a 6-volt system to carry suficient current (approx. twice as thick as the "standard" 12 volt cables most parts houses handle).....buy new cables & make sure all connections are good ,make sure your batt is good ( not a "$30 wal-mart" with only 500 cranking amps ), then if she won't start the M your starter is weak - & even when everything is "up to snuff" , you may still occasionally have trouble starting the M ( if your engine has been rebuilt with high compression pistons , or in real cold weather ) it is also possable ( happens at least occasionally) that you ( at least think) you have everything in good shape - the tractor will spin good on 6 volt & still not start right up all the time .....if you run into that problem , in addition to re-checkling starter , cables & connections you may need to tune up the elecrical ( points , coil , plugs , wires , cap & rotor)......what's happening if you run into this is that the cranking system is useing all of the avalabe juice & there's not enough left to fire the ingnition side (&/or the ignition side is "marginal") hope this helps ! ......sorry for the long post , i coulda just summed everything up with " 6 volts started M'e just fine when they were new & still will as long as everything is "like new" !
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
