Re: Farmall Starter
Posted by El Toro on August 12, 2006 at 08:01:07 from (152.163.100.65):
In Reply to: Farmall Starter posted by Crusher on August 12, 2006 at 06:38:59:
You need 00 battery cables with soldered ends. Heavy welding cable will work fine. Make sure all connections are shiny and tight. That includes where you're grounding the battery. Positive ground worked fine for years. Hal
Today's Featured Article - Tractor Profile: Allis-Chalmers WD45 (Gas Version) - by Staff. Beginning production in 1953, the WD45 had the same general look as the WD tractor which was produced earlier - but was much more powerful. This was due to the new 4-cylinder "Power Crater" gasoline engine with a 4 x 4-1/2 inch bore and stroke. Some people feel this was one of the most significant tractors offered by Allis-Chalmers in those days. Nothing in its weight or power class could match its performance. In 1954 they began offering the WD45 with the new "Snap-Coupler&quo ... [Read Article]
