Re: Farmall Starter
Posted by old on August 12, 2006 at 09:19:57 from (4.245.4.183):
In Reply to: Farmall Starter posted by Crusher on August 12, 2006 at 06:38:59:
Something every else missed it the fact that it could be a 12 volt starter and if so it will not work on 6 volts because it was made for the 12 volts. You need to look at the starter close and see if the tag if it has one says 6 volts or 12 volts. As I said if its 12 volts it will not work on 6 volts and you will burn it up tring
