Re: HELP PLEASE!!
Posted by CNKS on August 12, 2006 at 17:33:31 from (204.249.178.138):
In Reply to: HELP PLEASE!! posted by tyler cohrs on August 12, 2006 at 16:19:38:
There was only one carb for the M/W6, it came in gas or distillate versions, I think there is only one kit. Your Case-IH dealer has all the common parts for your tractor or can order them. If you do not have a dealer look at www.cngco.com, web address for a CIH dealer in WI that specializes in mail order. Valves are set at 0.017" hot using a feeler gauge. People have various was of adjusting valves. To quote the service manual: "This may be accomplished with the engine at low idle speed (somewhat messy) or by turning the engine to top dead center of the compression stroke for each cylinder and adjusting the valve lever clearance of each cylinder in the firing order (1-3-4-2)"--you really should get manuals for your tractor.
