Re: 656 tread width
Posted by Hugh MacKay on August 12, 2006 at 19:30:34 from (209.226.106.105):
In Reply to: 656 tread width posted by Don656 on August 12, 2006 at 19:15:20:
Don: Wheel tread is measured from center to center. The 4" discrepancy is probably due to which side of the cast center you have the lugs.
There is also very likely a difference if you have 34" pressed steel wheels. There could be a difference if someone has replaced the 38" rims with newer or wider rims
