Re: Re plugs fouling
Posted by GordoSD on August 12, 2006 at 20:09:40 from (66.115.200.140):
In Reply to: Re: Re plugs fouling posted by Wes in Ohio on August 12, 2006 at 19:59:10:
OK, more info is better. 4 hrs in 2 years? No internal combustion engine on earth can be expected to run properly with this use.
Are we going to go through a long drill to get this thing running so you can use it one hour nexst year?
You need to either get out and work the thing or accept the fact that it won't run well if you don't operate it more.
Gordo
