Farmall Tractors Discussion Board
Re: Generator like a motor
Posted by IHank on January 23, 2000 at 11:21:18 from (167.142.11.94):
In Reply to: Generator like a motor posted by Pipewrench on January 23, 2000 at 09:03:14:
Check the ink color on the ID tag on the generator. Delco Remey used the tag ink color to identify the proper ground polarity for the unit- red for positive ground and black for negative ground. Stuck cutout relay contacts are a common clue that a reverse polarity problem exists. Odds are high that you're gonna put on a new regulator, so be sure to do the generator re-polarizing procedure per the instructions with the new regulator. Good luck!
Post A Followup
: Re: Re: Generator like a motor
