Re: Re plugs fouling
Posted by the tractor vet on August 12, 2006 at 20:41:24 from (75.24.6.64):
In Reply to: Re: Re plugs fouling posted by Wes in Ohio on August 12, 2006 at 19:59:10:
Alwright Try this i\, i know that i'll get some flak here but BTDT Get the stock 6 volt coil and the ballast resistor From Case I H for the coil and install that make sure that ya put the termianls to the dist. the correct way for the polarity of the tractor . I have found that this system works better on all the ones that i have changed over from 6 to 12 . make sure that your plugs are gapped at the .025 . Whenit is idealing do you have any smoke comming out the exhaust ?? at ideal ?? . Now as for the main jet setting if everything else is wright i have never ever seen and over fuel problem on any stock tractor that i have worked on now if someone has drilled the main jet or the float is way to high then it can over fuel . Now as for the comperssion readings she is a tad low but hey she ain't new . My S H is in that range and i have no problem with fouling plugs on her . If ou were close to me i would give ya hand on it .
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
