Re: Leaking Belt Pully Gearbox Gasket on H
Posted by kfox on August 12, 2006 at 22:57:37 from (63.18.175.6):
In Reply to: Re: Leaking Belt Pully Gearbox Gasket on H posted by GordoSD on August 12, 2006 at 20:48:41:
That gasket is a little thicker than normal gasket paper(just bought one-7 bucks) Also there are two copper washers on top of the two long bolts. Probably not your problem. Arw you sure its not leaking from the pulley gearbox instead of the cover gasket? There is an expansion plug on the end of one of the shafts, ken
